OBD reset for inspection
Old 02-21-2014, 04:50 PM
dwh711's Avatar
Default OBD reset for inspection
Anyone know how many miles need to be driven in order for the computer to ready for an inspection?
Old 02-21-2014, 09:21 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
You need to run the readiness cycle- It is not a set number of miles. here is what the "book" says.
Attached Thumbnails OBD reset for inspection-technical-service-publications-001.jpg
Old 02-21-2014, 11:14 PM
dwh711's Avatar
Default Xj6 1997
Thanks for the reply. Would this be the case for a 97 XJ6 though?
Old 02-22-2014, 02:45 AM
GGG is offline
Received 16,823 Likes on 12,178 Posts
Unfortunately it doesn't relate directly to miles driven, it depends on 'drive cycles' (such as the one shown above for the V12) to complete the OnBoard diagnostic tests for:
1. Catalyst
2. O2 sensor
3. Evaporative purge system
4. Secondary air system
5. EGR system
These will eventually all complete with normal driving but it can take hundreds of miles.
I can't turn up a specific X300 6 cylinder drive cycle document but all the ones I've seen are similar to the V12 one Ross (sparkenzap) has posted.
Old 02-22-2014, 03:03 AM
sparkenzap's Avatar
Good eye! Sorry about that. Here is the MY 95 XJ6 document. JTIS many times does not repeat info for subsequent years if the info from previous years does not change, so I will bet MY 97 is pretty similiar to MY 95. And it IS somewhat different from the v-12 cycle.
BTW, you do not need to nail it exactly. If I drove 50 to 85 miles in my XJ6, at normal city speeds, it normally reset. The main point is, steady driving at varied, slower speeds. I have also heard that a 3/4 full tank helps (for the evap system test).
Attached Thumbnails OBD reset for inspection-technical-service-publications1-001.jpg
GGG (02-22-2014)
Old 02-22-2014, 05:28 AM
SleekJag12's Avatar
How about this method:
After a few days of normal and varied driving, they will all show ready (if all is well)... except for the catalyst monitor, which requires the steady speed driving for 3 minutes or so.
In Arizona, a 1997 model year would be allowed to pass its emissions test even if two of the monitors are "not ready," as long as there is no "check engine" light. Your state's rules may vary!
Of course you would only know this if you hooked up an OBDII scan tool. If you don't have one, the auto parts store will usually "hook one up" at no charge.
Msteiner
05-16-2016 12:19 AM
redxk8
10-04-2015 08:28 AM
inactualis
10-02-2015 11:13 AM
millertic
09-30-2015 08:11 PM
Quick Reply: OBD reset for inspection
