Hey,
I lost 2l of oil in just 2500km, I'm guessing it's due to a leak. Everytime I leave the car overnight, I find an oil stain when I return (about 5-6 drops of oil).
It's under the right side of the engine (slighty middlish).
They are also susceptible to an leak from the front right of the head gasket where a high pressure oil pipe is located very close to the edge of the gasket.
You will need to follow above advice and give it a good clean first to determine source.
