P1621 Error Code
Old Feb 18, 2020 | 05:54 AM
nickdabs's Avatar
Default P1621 Error Code
Hi All,
What was the final verdict on this error code - 1621 this is the only code that comes up when I scan my XJR6, is this something I should be concerned about?
Cheers,
Nick
Old Feb 20, 2020 | 12:28 AM
SleekJag12's Avatar
"ECM Engine Immobilisation Input Circuit Malfunction"
"A range check on the diagnostic L-line is performed to check for voltages outside expected limits. On detecting out of range voltages the appropriate fault code is stored and the MIL lamp illuminated."
That's all I see about P1621. I don't quite understand what it means, or if it is a real problem.
Is your MIL illuminated? Do you have other symptoms that could be causing the code, like with security or immobilisation?
Old Feb 21, 2020 | 05:59 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
I think P1621 is a sporadic random code.
I spent several weeks chasing this "ECM Engine Immobilisation" error trying to track down a supposed security or immobiliser fault while trying to get to the bottom of intermittent starting (would always crank but not start). In the end this turned out to be a faulty crankshaft position sensor.
The car still periodically logs a P1621 even though there are no issues with it.
Chris Benyo
Apr 28, 2020 01:45 PM
cforne7
Oct 8, 2019 09:06 PM
jelu02
Jun 8, 2018 08:09 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
