Poor Jag won't start
Old Dec 28, 2008 | 05:51 PM
AJ16er's Avatar
Default RE: Poor Jag won't start
Battery. These cars do these things if the battery voltage is even slightly low. Take the battery out and charge it, if you don't have a charger take itto your local auto parts storse and have them charge it. Try this first as this is the most likely and obvious cause.
I personally would not jump cars or jump start this car because they have sensative electronics that you risk frying with jumps.
Old Jan 1, 2009 | 10:13 AM
AJ16er's Avatar
Glad to hear your car is fine. Yes, avoid jumping with a complex gadget laden luxury car unless a complete emergency. Chances are nothing will happen but then again there is the small chance of frying some expensive electronics.
Old Jan 2, 2009 | 10:05 AM
Forestred's Avatar
Hi,
I just read your post as my Jag is currently a non-starter. I would agree with the others, it is not recommended to jump any car that has an ECU (often called an ECM) without using jump leads with diodes inline to prevent current surges going back to the source car and frying the engine management system.
Regards
Fr
fast40driver
Apr 19, 2024 07:24 AM
1964Daimler
Sep 2, 2015 11:41 PM
Rusty1952
Sep 1, 2015 05:45 AM
cheaperts
Aug 30, 2015 06:48 PM
Drew2006
Aug 28, 2015 04:22 PM
