Power steering leak
Old May 24, 2023 | 12:16 PM
DoccyG's Avatar
Default Power steering leak
I have a 1996 Jaguar Sovereign 3.2 straight six that I brought out from England to Barbados,where I live, in 2016. I have been lucky with reliability so far but I now have a leak from a perished hose from the pressure cylinder of the power steering. My mate, a mechanic tells me I need a new pressure hose. I have found a few diagrams but I can’t find the part number. Can anyone help me find the part number so I can order one from the UK?
Thanks in advance
Old May 25, 2023 | 02:45 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Jaguar X300 Power Steering Hoses Parts List
Old May 25, 2023 | 11:56 AM
DoccyG's Avatar
Thanks. I think it is 19 I need so I can order it now.
Old May 26, 2023 | 05:13 AM
bjarnetv's Avatar
Remember to order the OEM part, even if it costs more - the cheap aftermarket ones are not rated for the pressure and will start leaking quickly (happened to me twice before i bough an OEM hose)
Old May 26, 2023 | 07:22 AM
DoccyG's Avatar
Good tip, Thanks.
a
Apparently there are some hoses available on the island which are home made and unreliable.
Having a recommend brand is great.
Old May 26, 2023 | 07:38 AM
bjarnetv's Avatar
i got mine from https://parts.jaguarlandroverclassic.../brand/jaguar/
but it seems the RHD hose is twice as expensive as the LHD one for some reason!
If you know of a hose-specialist with a good reputation locally it might be better to have them remake a new hose while reusing the metal pipes and fittings of the old one.
Old May 26, 2023 | 10:31 AM
Vee's Avatar
Vee
There must be a hydraulic hose shop on the island to service and replace ruptured hoses on industrial and construction vehicles/equipment.
If you bring them the old hose, they can reuse the metal ends and replace the rubber sections.
Will a used hose approximately 30 years old last very long?
Old May 26, 2023 | 10:40 AM
DoccyG's Avatar
Thanks, it may be my only option.
lickahotskillet
Oct 31, 2016 09:53 PM
hugh ness
Feb 29, 2016 06:20 PM
hugh ness
Feb 28, 2016 02:14 AM
