Rear abs sensors
Old Nov 24, 2020 | 01:33 PM
Shanex300's Avatar
Default Rear abs sensors
Hi I was wondering if anyone can help me please I have a 1995 x300 xjr and I need both rear abs sensors but can't seem to find them any where as I believe they have been discontinued. Would be grateful for any advice thank you.
Old Nov 24, 2020 | 06:14 PM
xalty's Avatar
look for 98 audi a4, you’ll have to change the connector and add a spacer
alternatively you can use the late 300/308 sensor and superglue it to the hub carrier (easier than drilling a new hole for the bolt) but you’ll need the link harness and still need to put the old style connector on it.
Old Nov 26, 2020 | 11:38 AM
aholbro1's Avatar
The '97 X300 sensor will work but you need the compatible wire looms that will plug-n-play under the rear seat cushion. You will have to "modify" the sensor mounting - either via super-glue or making an adapter as is depicted in a thread in here somewher, as mounting it to the only screw-hole in the '95 hub will point the connector directily outboard, leaving you no room for the wiring or connector.
Shinda’s XJR
Mar 28, 2024 07:48 PM
JensenHealey
XJ40 ( XJ81 )
Jun 1, 2020 10:13 AM
Graham Sears
Oct 22, 2019 05:17 PM
batroute
Apr 19, 2014 03:17 PM
randyb
Jun 23, 2013 07:11 PM
