Turn signal issues
Hello everyone. I have an issue with my right had turn signals, so all the front, side, and rear lights. I change out the bulbs on the front and the rear, that didn't work, so then I tried changing out all the fuses in the trunk fuse box, and that didn't work either. I have 1997 Jaguar XJ6. I just needed a little extra help on this matter so I can try to fix it as soon as possible. Thank you.
At the lower corner of each front wing (mudgaurd) where the undertray meets the arch liner, is a multi pin plug.
One on each side.
Dig in there as best you can. Mine does not have that undertray, so access is SIMPLE. Seperate that plug, use Lemon Juice to clean ALL the gunk, Green growth, etc from both sections, I then spray it with WD40, and replug it.
Always brings the lamps back to life. Did mine 6 weeks ago, all good.
One on each side.
