Vibration from brakes at very low speed
Old Oct 18, 2020 | 04:31 PM
JezuzNoChill's Avatar
Default Vibration from brakes at very low speed
There is a vibration from the brakes shaking the car at crawling speed like right before coming to a stop. Is this a common problem? And what's the fix?
Old Oct 18, 2020 | 07:30 PM
NO not normal.
Mine did that. Tried all sorts, eventually I unplugged the ABS module, problem solved.
Then read about issues with dry solder joints inside that module, had that sorted, never vibrated again.
That unplug is a FREE diagnosis, and if it does NOT change/fix that vibration, then teh $$ start getting needed.
My "R" did it twice on the home bound cross country run, and I also unplugged that module until I got home, and had that one sorted as well.
NOTE, REPEAT NOTE
With that module unplugged you have NO ABS system. the brakes work fine, just like any None ABS car, just YOU will need be aware of how you drive, as there is NO ABS.
If you are uncomfortable with that, OK. Modules are out there.
Old Oct 20, 2020 | 03:16 AM
countyjag's Avatar
The issue, I think, is dirty ABS sensors. My jag isnt particularly badly affected, but other beloved cars suffer from it if they have been standing idle for a while. I find it can be worse if I am turning, say into a parking space, and for the last revolution or so, the abs just releases one of the wheels briefly. Reinstating regular use seems to clear it pretty quickly, but I have on occasion cleaned the sensors and reluctor rings which has solved it. I have only ever experienced it on a front wheel, and I think it is caused by the dirt causing there to be a marginally different signal being generated by each wheel. Not a big deal when driving along, but proportionately much more significant at very low wheel revolutions, causing the abs system to think a wheel has locked.
shma85
Jul 9, 2018 11:17 PM
Unhingd
Apr 24, 2015 11:29 AM
bollocsk187
Oct 22, 2014 01:14 PM
mggvisions
Oct 14, 2013 09:14 AM
Dermot
Jul 25, 2009 04:11 PM
