Welding & electrics
Old Jun 9, 2021 | 04:00 PM
Stu Jags's Avatar
Default Welding & electrics
Have been doing some welding on my X300 and now most the electrics don’t work. I have interior lights, side lights, electric windows but nothing much else. Any suggestions appreciated.
Old Jun 10, 2021 | 09:59 AM
Parker 2's Avatar
What kind of welding other then where it was at ?
Old Jun 10, 2021 | 03:39 PM
Stu Jags's Avatar
After some research I was pointed towards inertia switch. Sure enough my hammering had tripped it. Once reset everything works perfectly. If none of your electrics work, that would normally work when the ignition is on then check the inertia switch as it seems to kill the ignition feed. To check inertia switch just push down on the top of the rubber top and if tripped you will hear and feel a click. Hope this helps someone else one day.
Old Jun 10, 2021 | 04:11 PM
Cafcpete's Avatar
Excellent find, and thanks for reporting the fix!
mikega
May 1, 2021 06:29 PM
omgimali
Jun 3, 2020 04:39 PM
sirmikeluv007
Feb 26, 2019 02:33 AM
harryf
Jul 2, 2018 10:39 AM
WesSide
Audio/Visual Electronics
Jun 1, 2010 05:32 PM
