Wheels interchangeable?
4 Attachment(s)
Just picked up a 1996 XJ6 with 92K miles yesterday, BRG with biscuit interior, for $3400. Clearcoat is shot on the roof, and lots of crowfeet on the hood, but a very solid car otherwise.
Attachment 164419 Attachment 164420 Attachment 164421 Attachment 164422 Put new tires on it, 225/60-16, and was wondering about swapping the wheels with some other make. From what I can tell, my stock Jag wheels are 16x7, 5x120 bolt pattern? BMW e38 wheels have the same bolt pattern (5x120), but not sure if the offset and backspacing is compatible. Does anyone know if the e38 mesh-style wheels will work? Thanks |
Anyone? Anyone? Bueller? Bueller?
Folks over at the Saab forum (I have a '91 900 turbo convertible) chimed in with some opinions. Seems that there actually is a difference between the 5x120 (BMW) and 5x120.65 (Jag) wheels. Apparently, 5x120.65 is the same as 5x4.75", which is a typical Chevy bolt pattern. Only variables now are the offset and backspacing...
....and center hole diameter. Jag hubs require a larger-than-typical center hole.
Cheers DD |
Originally Posted by Doug
(Post 512864)
....and center hole diameter. Jag hubs require a larger-than-typical center hole. Cheers
DD As for the Jag, I took the spare out (which is full-size, and looks like the rest of the wheels), and it's stamped with 16x7, 33mm (offset I'm assuming), and that's about it. So the bolt pattern is 5x120.65 (4.75"), and I measured the center hole as 73mm, backspacing as 5 7/8"? Can anyone confirm the center hole opening and backspacing on these wheels? |
Hi Robert,
The rest of us are probably wondering what's not to like about the dimple-mags? (not my cup-o-tea for I have aero's...still...would be a clear 2nd choice) Good luck in your quest...wheels can be tough to find info on..... |
2 Attachment(s)
If all 4 wheels looked alike, I wouldn't have an issue with them. But for some strange reason, one wheel looks new, but the other three have definitely been around the block a few times. Strange...
The wheels are kinda plain in my book, with a lot of aluminum there. Would like to get something where you can see what's behind 'em, and most XJ6 wheels that I've seen are more or less full face as well. I also have a '91 Saab turbo convertible, and swapped the stock 15-hole alloy wheels (which were a PITA to keep clean) with some later model "twisted" 3-spokes. I'm trying to stay away from multi-hole / multi-vaned wheels, which just traps brake dust and dirt, and take a while to clean. Attachment 164365 Attachment 164366 If the Jag bolt pattern is the same as some Chevy models, wheels like the 5-spoke IROCs would look decent, easy to clean, and show the rotors and calipers. This is my first Jag, and this one's a keeper, so we'll see if this is just a wheel phase I'm going thru, lol! |
So we have Cheby bolt patterns?????
Originally Posted by 1badcat
(Post 516735)
Cheers DD |
1 Attachment(s)
Originally Posted by aholbro1
(Post 513315)
Attachment 226616 Dimple is such a good design. |
The only Jaguar XJ/XK V8 wheels I know of that will fit the X300 are the X308 VDP with hub caps. The others will need to be modified in some way because of the front hubs.
bob gauff |
http://www.minilitewheels.us/images/sce/EV_500.jpg |
(Post 516884)
bob gauff FTR I have XJ8 wheels on my X300/XJR. Not sure what style they are....the plain-vanilla, standard issue 16x7 XJ8 wheel from 1998-2001 or whatever. They fit fine *except* that they foul the wheel bearing dust caps on the front. I had to ...ahem....cough cough ...."re-contour" the dust caps a bit :-) Cheers DD |
(Post 516894)
They fit fine *except* that they foul the wheel bearing dust caps on the front. I had to ...ahem....cough cough ...."re-contour" the dust caps a bit :-) Cheers DD Pics of your car??? |
Originally Posted by socal1200r
(Post 512473)
http://i803.photobucket.com/albums/y.../DSCN1191a.jpg http://i803.photobucket.com/albums/y.../DSCN1194a.jpg http://i803.photobucket.com/albums/y.../DSCN1195a.jpg http://i803.photobucket.com/albums/y.../DSCN1196a.jpg Put new tires on it, 225/60-16, and was wondering about swapping the wheels with some other make. From what I can tell, my stock Jag wheels are 16x7, 5x120 bolt pattern? BMW e38 wheels have the same bolt pattern (5x120), but not sure if the offset and backspacing is compatible. Does anyone know if the e38 mesh-style wheels will work? Thanks |
(Post 516946)
Pics of your car???
In essence it looks just like this: 1998 Jaguar XJ8 L Start Up, Engine, and In Depth Tour - YouTube Of course there are a few differences in X300 versus X308 lights and bumper trim...but they're very minor Cheers DD |
2 Attachment(s)
(Post 516948)
Did you buy yours from a privit party or dealer?Looks like a clean car! I paid 2000 more and isnt as clean as yours on the inside (unless pics lie) and mine is the sc version......
I was thinking of getting a set of IROC wheels like these, 16x8, zero offset, center bore opening 73mm (s/b same as the Jag's): Attachment 164309 I think the center area of each of those spokes would look good painted green, to match the car. Subtle, but would tie in the color of the car with the wheels. Main issue is the zero offset 8" width would push the wheels out, maybe to the point where they'd bottom out on the fender lip, instead of clearing it like they do now. Here's a different set: Attachment 164310 Someone on the Saab forum gave me this website as a reference for tire and wheel fitment: Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator (hopefully this opens) Lots of things to take into consideration on getting different wheels, and the main ones seem to be offset/backspacing, and more importantly, center bore diameter. Those dimple mags are just too plain for my liking, and they're so solid, can't see anything behind the wheels, like the brake calipers and rotors. Since I plan on driving my '91 Saab 900 turbo convertible cross-country in Aug, I might just hold off on doing anything wheel-related, until the trip is done. But, if there's a smoking deal on a nice set of wheels, like those 5-spoke ones above w/o the tires, I might just have to take the plunge now and get the tires swapped later... |
5 Attachment(s)
(Post 516884)
bob gauff Attachment 226611 Here is another X305 with that wheel: Attachment 226612 Attachment 226613 Look damn good, huh? Someone even put them on their XJ Coupe racecar: Attachment 226614 Actually looks OK with the the old body. There is also another, somewhat similar, XKR wheel that looks pretty good on the X300: Attachment 226615 |
I have seen the wheels installed WITHOUT the metal hub bearing caps but the grease might leak out!!!!
Maybe there is a different cap?????? bob gauff |
2 Attachment(s)
Another option that I've heard should work are the 5x120 wheels that are common on BMWs. 'Course the BMW logos would be removed!
These wheels would work, since they're 16x7, +20mm offset, with a 74mm hub opening: Attachment 164307 I'd prefer these wheels (16x7, +20), but the hub opening is just a pube too small, at 72.56 (I believe the stock Jag ones are 73mm): Attachment 164308 |
