X300 MAF charts
Old Jan 29, 2024 | 04:37 AM
kestaszn's Avatar
Default X300 MAF charts
Hello,
Maybe someone has MAF charts to compare LNA 1620 AA (x306 xjr automatic) vs LHE 1620 AA (x303 3,2ltr automatic) vs LNC 1620 AA (x306 xjr manual)?
Old Jan 29, 2024 | 08:37 AM
Parker 7's Avatar
I saw a factory chart but it does not specify which AJ16 engine
Saved it to an old broke computer
At the proper idle speed they should all read 1.2 volts DC on the connector middle wire
As an engineering rule of thumb for every liter of displacement at 700 PRM it should draw 1.0 grams per second as a parameter ID with a ELM - 327 device
This would only prove it is alive
There is a software error in some of the devices where you have to multiply the MAF value by 10 or 100 , Chinese copycats from the original Canadian company patent
At wide open thottle you should see 175 g / sec on the 4.0 and 225 g / sec for a factory supercharger setup
The voltage value would be approaching 5
There us a TSB to not race the engine stationary like a driveway , may have to do with transmission / torque converter cooling
Old Jan 29, 2024 | 08:56 AM
kestaszn's Avatar
Chart I have managed to find is attached. But as You say. It does not mention, which model exactly it is. Some say that it's of XJR.
File Type: pdf
Old Jan 29, 2024 | 09:05 AM
Parker 7's Avatar
The chapter that it is mentioned in is the supercharger as a clue only but you can compare to the 175 / 225
Old Jan 29, 2024 | 09:10 AM
kestaszn's Avatar
According to the table at 4,7V it provides 284g/s :/
Old Jan 29, 2024 | 09:15 AM
Parker 7's Avatar
The chart was probably supplied from Lucus with the high and low values not the subject engine's idle and max RPMs
It may not account for supercharger gas compression
The electronic governor engine ECU RPM is higher then the transmission ECU shift point of sport mode 5000 and more like 5850
Old Jan 29, 2024 | 07:15 PM
Jagboi64's Avatar
That flow rate vs voltage is the XJR's MAF. I'd be curious to know what NA chart looks like too.
Ashton Dimovski
Aug 28, 2025 04:56 PM
Bosco15
Oct 29, 2022 12:55 AM
LeJaguar
Feb 11, 2022 02:59 PM
JTsmks
Dec 6, 2017 01:06 PM
dcdecs
Feb 11, 2015 07:15 AM
