X300 oil pressure indication
Old Oct 2, 2017 | 01:47 AM
Atco's Avatar
Default X300 oil pressure indication
No oil pressure indicated at tick over. On acceleration pressure is indicated but on the over run no pressure indicated even when engine is still turning at 2000rpm. I have changed pressure switch twice.
Loose connection somewhere?
Any thoughts?
Old Oct 2, 2017 | 05:38 AM
RJ237's Avatar
Remove the sender and connect a mechanical oil gauge temporarily, just to be sure you have pressure. A local shop should be able to do that, it doesn't have to be a Jag specialist.
