XJR6 camshaft sprocket bolt torque spec
Old Mar 26, 2024 | 01:46 PM
RonXJR's Avatar
Default XJR6 camshaft sprocket bolt torque spec
Hi all,
I am replacing the head gasket on my 95 XJR6 and can't find the 4 bolt camshaft sprocket torque in the manual.
Does anyone know the correct specs for the camshaft sprocket retaining bolts?
Thanks.
Old Mar 28, 2024 | 07:50 PM
Parker 7's Avatar
See file below in the beginning pages of torque specs
There is a stamped dot on the head bolts to not reuse them more than X # of times
Old Mar 29, 2024 | 12:10 PM
RonXJR's Avatar
Thanks for the information. I bent the tab and removed the cam retaining bolts and requires about 30 ft-lb which correlates the cam coupling bolt spec on the manual.
drmike
General Tech Help
Sep 29, 2021 01:18 PM
damurna7
20
Jan 20, 2019 06:10 PM
jaghag00
Jan 14, 2017 09:28 PM
lawnerd
General Tech Help
Jul 2, 2014 06:42 AM
BonoVox11
May 23, 2009 09:42 PM
