Center console central locking button clock hazards
Hey guys none of the buttons work in this panel dose it just fail ive checked all fuses elays all seen fine do i need to remove it and see wats going on behind it or could it be prob elsewhere in not fussed about the clock 🤙
There is one plug with all the related wires going into that middle unit. It could be unplugged. The clock probably won't display right anyway. Maybe thats why it got unplugged. But yes that would also disable locking and hazards. The clocks always fail but the other functions don't fail.
Careful with the frame that holds the center console stack. The screw tabs will be very brittle if not already broken. Same goes for the shifter surround.
