01 XJ8 Coil Packs
Old Nov 3, 2009 | 08:10 PM
GeorgiaXJ8's Avatar
Default 01 XJ8 Coil Packs
Any way to test the coil packs? I have codes reading bad coil pack #4 and #7. I have removed the packs and checked the plugs. The plugs look new. I just purchased the car and i'm trying to check everything. I also have codes saying knock sensors and crankshaft position sensor, to name a few. I have read on the forum that the knock sensors could be a bad connection. If this is true, I will try to check the connections. I need help!!
Old Nov 4, 2009 | 05:40 AM
sparkenzap's Avatar
Georgia:
Just a thought. These cars are known for voltage sensitivity in the ECU- Weak batteries are blamed for everthing from ABS modules faults (valid) to gas mileage (???), and some of these claims are probably valid. With your new alternator, I would reset the codes, then wait a few days before finishing your campaign, since Jag parts are pretty expensive.
Old Nov 4, 2009 | 05:47 AM
GeorgiaXJ8's Avatar
The car is definitely missing at idle, but not under acceleration. Would you still wait for the alternator before going forward?
Old Nov 5, 2009 | 07:57 AM
GeorgiaXJ8's Avatar
Changed the coil pack on cylinder 7. Reset codes. Waiting to see if I get another. Still have a miss at idle, so cylinder 4 may still be missing. I ordered another coil pack just in case. Just waiting for codes....
Old Nov 5, 2009 | 01:38 PM
sparkenzap's Avatar
George:
It sounds like you are on to it. It also sounds like the PO "deferred" a lot of repair. When you get these few s****lies worked out, you will most likely find you have a reliable, purring kitty.
Old Nov 5, 2009 | 01:42 PM
sparkenzap's Avatar
"s****lies" ????
That is the most ridiculous censoring I have ever seen. I guess I should have spelled it s-n-i-g-g-l-i-e-s. PC run amuck.
Old Nov 6, 2009 | 11:44 AM
GeorgiaXJ8's Avatar
Ok. Been driving for a day and no codes so far. Still have the miss. Also have another problem, possibly related to the battery problem I posted. The car does not start all the time. I have a new battery in it and yesterday it was fine. Today, no start condition. Appears to be a weak battery again because I am getting some messages about check rear lights and transmission fault. It did this when I had the old battery in it. Any ideas????
Bcrary3
Feb 21, 2023 04:29 AM
Mugatu
22
Jun 23, 2020 01:50 PM
bdboyle
Sep 16, 2019 05:58 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Dicque
Sep 19, 2015 12:53 PM
