02 xj8 fog light replacement
Old Sep 3, 2008 | 01:47 PM
ilovetrains's Avatar
Default 02 xj8 fog light replacement
the manual suggests the dealer do this, why?
I assume I will have to remove the bottom air dam from the backside of bumper to get to them, is that all?
Old Sep 6, 2008 | 06:37 AM
Markus's Avatar
Default RE: 02 xj8 fog light replacement
Dealers need revenue, that's why!
To change bulb:
Remove undertray
Disconnect bulb multiplug from the bulb
Rotate bulb, remove, replace (don't touch glass part of bulb with fingers - if you do, clean it with denatured alcohol to prevent hot spots and premature bulb failure).
If you need to replace the entire light, just 3 screws to remove.
Cheers!
________
1999 XJR
Old Sep 10, 2008 | 12:01 PM
thanks, did not look that difficult, but wondered if there was a special tool involved for some part of removal. Had that on another car, special tool turned out to be a torx head driver.
MJ'S Jag
Nov 10, 2022 08:14 AM
MarathonJohn
Sep 3, 2015 07:59 PM
Jandreu
Aug 29, 2015 07:31 PM
jagmanv8
Aug 28, 2015 12:28 PM
Will P
Aug 27, 2015 06:52 PM
