1998 XJ8 Sovereign Aerial Wiring?
Old Apr 16, 2011 | 09:01 PM
Rae's Avatar
Rae
geodesics: There is no connection between the boot being open and the mast going up or down, that I know of. Is the motor working now? If so, then the plastic toothed cable inside of the arial is probably stripped. You can buy a new mast with cable pretty cheap on e-bay. Easy enough to replace. If you can't hear the motor now while in the trunk, with someone inside turning the radio on and off, then perhaps the wiring harness work did affect this. I've seen stranger things happen. Good luck.
Old Apr 17, 2011 | 06:41 AM
SuperSport's Avatar
If you pull the right side carpet panel, you can clearly see the wiring going into the Aerial. From there, you can follow it up and see if it got cut or disconnected during the other repairs.
Also, I believe Fuse #9 in the Trunk is for the Aerial. Maybe it got blown?
Old Jun 14, 2011 | 07:33 PM
garymtyler's Avatar
hopefully you can help me.....someone pulled the three wires out of the socket part of the plug that plugs into the aerial motor mechenism. i do not know which holes in the plug the wires go in, nor what order. many thanks
Old Jun 15, 2011 | 02:22 AM
QuadManiac's Avatar
The wiring diagram for the 98 is here:
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
DrTripp
Mar 22, 2020 09:33 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
leep123
Sep 26, 2015 04:53 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
prettydaim
Sep 10, 2015 04:27 AM
