1998 XJ8 Vibration
Old Nov 7, 2008 | 08:44 AM
ken@britishparts.com's Avatar
Default RE: 1998 XJ8 Vibration
Can you drive through the vibration? Perhaps you have a wheel out of balance.
Old Nov 7, 2008 | 08:14 PM
Brutal's Avatar
can you post a pic? ive never seen a Jag with 154k on it.......JK
actually I would ck several external things, 1if the rubber jurid coupling have cracks, replace them(they perform the function of u joints on the driveshaft) make sure driveshaft bolts are tight, I occasionaly find them loose. and check to make sure the motor mounts and trans mount isnt broken. If these all ck out fine, drive to point its the worse and shift into neutral letting the engine rpm drop, does the vibration go sway or significantly reduce?
Inspector
Oct 17, 2015 12:51 PM
Tally Ho
Oct 1, 2015 01:49 AM
donald ebanks
Sep 30, 2015 07:08 PM
Johnken
Sep 30, 2015 02:46 PM
