1998 xj8 wiper problems
Old Oct 16, 2012 | 04:49 PM
ohkyguy's Avatar
Default 1998 xj8 wiper problems
The issue I am having is the wipers only work on high. the washer does work. No blown fuses and I wsapped the relays and no changes. I unplugged the motor and I can see ground and positive on the plug side. I do get ground and positive on different pins when changing from slow to delay to high. So it appears there is no issue with the staulk mount,relays or fuses. I wanna be sure though. Does anyone know what the five wires do on the motor plug. It appears the 2 black ones stay on ground. The blue I believe swiches to 12 volts when the wipers are on high and I think the red/yellow is constant 12 volts. There is also a red wire not sure what it does. I just need to know what to hook up these 5 wires to so I can test the slow speed as well as the faster speed and I assume I wont be able to bench test the delay. Thanks
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
mcdutch
Sep 4, 2015 03:38 AM
arnoldmilk
Sep 3, 2015 07:42 PM
XJsc-guy
Sep 2, 2015 11:43 AM
