2001 Xj8 service light reset
Old Sep 11, 2011 | 04:45 PM
Roy H's Avatar
Default 2001 Xj8 service light reset
Hi.Loving the xj8 and just completed a service.
I have a service lamp due indicator( i think anyway) with 5 amberlights and a redlight bar above the mileometre.Its on red now
Tell me please guys how do i reset it.
Many thanks
Old Sep 12, 2011 | 01:36 AM
sparkenzap's Avatar
Roy:
The X-308 does not have a "service soon" light. I do not understand your comments about amberlights and so on, but I THINK you are referring to the "check enginelight" which indicates there is something wrong. Getthe codes read with an OBD scanner.
Old Sep 12, 2011 | 02:25 AM
Roy H's Avatar
Thanks Ross.Oh no i have trouble then.
I have a code reading P0430 Catalyst System Efficiency Below Threshold (Bank 2).And what is it?
Will that cause the warning light to come on ?
Old Sep 12, 2011 | 04:34 AM
Sean B's Avatar
Hi Roy, how many miles has the car done? The O2 sensors are like spark plugs and do have a service life. Have you noticed a lowering of fuel economy?
If not then there's not much to worry about. I've had this on a relativity high mileage XJ, it came on after long runs. Yes it will cause an amber light, but not a big problem. If your economy has gone down, it might be a case of replacing the offending O2 sensor.
BTW you're just round the corner from me and another member Stu.
Old Sep 12, 2011 | 12:05 PM
Roy H's Avatar
Hi sean .thanks alot for that.
Small world we live in.
Cars done 54,000 mile and im getting around 25mpg.
Not had it long but mpg hasnt changed.I cleared the code and its gone.
I will see now if it comes back,if it does ill change the 02 sensor.Where is it, do you know please.
Old Sep 12, 2011 | 04:00 PM
Stu 1986's Avatar
Yes very small, and I have a wealth of spare parts for sale including 02 sensors! PM me or Dr Jag if you want anything.
Old Sep 13, 2011 | 02:19 AM
Roy H's Avatar
Thanks Stu,Good to know someone is local .
Ill do another scan when it pops up and be intouch
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
bdboyle
Sep 4, 2015 06:16 AM
