2001 XJR Temperature Display
Old May 6, 2012 | 09:01 AM
Geordie1's Avatar
Default 2001 XJR Temperature Display
Hi all fron Scotland, I recently bought my first Jag, 2001 XJR, enjoying every minute driving it, only one very small issue, there does not appear to be any backlight in the interior / extreior temperature disply, the rest of the dash is ok, can someone please advise if the bulb be replaced, or does the unit need replacing?
Old May 6, 2012 | 11:49 AM
Sean B's Avatar
yep, it's just a bulb out, if you have a search within this forum, there's a number of threads on the subject.
Welcome and enjoy the forum, and your car.
Old May 6, 2012 | 03:12 PM
JaguarXJR02's Avatar
you have to get the shifter trim off, then the wood veneer around the shifter off, then I think you can unscrew the various units: climate control, radio, etc
I removed the console a couple of months ago to modify my ash tray to hold a scanguage, from what I remember:
1. shifter trim: lift up gently until it releases. then unbolt the black plastic with the s button and cc button. then unclip wiring for the S button and the cc button
2. wood veneer: there may be screws, maybe not. then lift up at the base near the cupholder and pull up and out
3. I think then you can see the screws that cold the climate panel in.
I haven't personally messed with the climate panel but what I know should at least get you to the panel
good luck
Old May 6, 2012 | 03:35 PM
Geordie1's Avatar
Default Geordie1
Thanks, I will have a look tomorrow.
Forcedair1
Feb 19, 2020 01:51 PM
drewlabarbera
Sep 14, 2015 07:46 PM
skadmiri1
Sep 9, 2015 11:27 AM
Kmw
Sep 8, 2015 04:52 PM
tberg
Sep 7, 2015 07:32 AM
