2003 XJ8 Water pump replacement help
Old Feb 5, 2020 | 12:28 PM
bzzt's Avatar
Default 2003 XJ8 Water pump replacement help
I've watched a couple of different videos on changing the water pump, as well as reading various threads on here. It seems simple enough but im running into a few issues.
2003 xj8 4.0
Is there some way to get the hook or if the way without taking it off?
what all has to be removed to get to the water pump easily?
Thr videos ive seen skip over these parts, and my car doesn't have the same amount of space or layout as the others othersgo straight into removing the belt, etc.). Can anyone provide a little assistance?
Old Feb 5, 2020 | 03:01 PM
Carnival Kid's Avatar
Originally Posted by bzzt
I've watched a couple of different videos on changing the water pump, as well as reading various threads on here. It seems simple enough but im running into a few issues. 2003 xj8 4.0
Is there some way to get the hook or if the way without taking it off? what all has to be removed to get to the water pump easily? Thr videos ive seen skip over these parts, and my car doesn't have the same amount of space or layout as the others othersgo straight into removing the belt, etc.). Can anyone provide a little assistance?
It took me a while to interpret your text...........I think what you are asking is "is there a way to get the hood out of the way without taking it off". And the answer is, taking the hood off is a PITA, and really not necessary to remove the water pump.
Removing the water pump is a pretty straightforward process. 1) To avoid anti-freeze running all over the front of the engine and the floor, undo the radiator drain plug and drain a portion of the antifreeze into a clean container. 2) remove the large radiator hose to give better access, 3) loosen the three bolts holding the waterpump pulley. 4) remove the serpentine belt . 5) remove the waterpump pulley. 6) undo the bolts holding the waterpump and remove the waterpump. 7) Replace with new waterpump and gasket. (may want to replace the thermostat while you are there) 8) reassemble and refill with antifreeze.
Waterpiumps and gaskets are available at economic prices at Rock Auto.
Old Feb 5, 2020 | 03:08 PM
bzzt's Avatar
Yes, i meant hood out of the way. Swype and me not paying attention. Thanks for your reply.
Red Baron
May 30, 2018 04:48 PM
Staufferooskie Jason
Oct 1, 2016 08:31 AM
jmbpharris
Dec 7, 2014 11:57 PM
kert1224
20
Nov 7, 2014 01:41 AM
ObxjagXJ8
Apr 6, 2014 12:50 PM
