2003 XJR Replacement Seat Leather?
Old Oct 16, 2013 | 02:49 PM
odds's Avatar
Default 2003 XJR Replacement Seat Leather?
Hello everybody, I just got off the phone with my local Jaguar dealer. They will sell replacement seat leather for the driver's seat for a whopping $2262. I have a 2.5-3" tear in my driver's seat right behind where someone's shoulder would be.
Can anybody recommend a third party website or maybe even a leather specialist that can replace the leather cover?
Or does anyone know of an X308 XJ being parted out that still has the leather driver's seat in black?
Many thanks,
Matt
Old Oct 16, 2013 | 03:22 PM
bigcat777's Avatar
Ouch!!
Old Oct 16, 2013 | 04:08 PM
dsnyder586's Avatar
Hey Matt,
I know upholstry shops can sew in a new leather panel and it should come out looking almost perfect.. or you can take a different seat and use a panel from it.
Old Oct 16, 2013 | 05:12 PM
OldMike's Avatar
I don't know if this helps or not, but take a look at this partout -- https://www.jaguarforums.com/forum/p...ng-out-104523/
Old Oct 16, 2013 | 06:04 PM
theusualsuspect's Avatar
i cant believe how crappy the xjr leather is compared to the vdp
Old Oct 16, 2013 | 07:01 PM
Platinum XJR's Avatar
Originally Posted by dsnyder586
Hey Matt,
I agree.
Have a shop sew in a new panel.
Or, you could have a mobile upholstery repair company come to you and fix it.
It is amazing at how good some of these mobile leather guys are!
Here is a local shop I think I am going to have fix a 2" cut in my back seat lower cushion.
You should have similar companies close to you.
Take a look at the our work section.
Stewart
Old Oct 16, 2013 | 07:46 PM
princemarko's Avatar
I got quoted $2400 for two new front reupholstered seats with cross stitched leather inserts and memory foam at a place here in Tampa.
Old Oct 16, 2013 | 08:03 PM
dsnyder586's Avatar
Memory foam? Wow, THATS luxury.
Old Oct 16, 2013 | 08:36 PM
danielsand's Avatar
I would definitely get both front seats from the junkyard (to match). Two should be about six bills (CHEAP) or less.
Old Oct 16, 2013 | 10:13 PM
dsnyder586's Avatar
I'm with Danielsand on that one- if you are patient, I am sure there will be the opportunity.
Old Oct 17, 2013 | 03:30 AM
Sean B's Avatar
I have a full set of Black leather skins from an XJR 2001 (USA 2002) from a low miles car.
Shipping would be the dealer breaker I would guess it's expensive to post from UK.
Make me an offer. To swap the skins you'll need Hog rings and Hog ring pliers, and a good set of side cutters/snips to cut the old rings. A T50? torx bit to remove the 4 bolts holding the seat(s) to the floor pan. A relativity easy job.
Old Oct 17, 2013 | 09:56 AM
luc's Avatar
luc
What is your leather color? If it is Warm Charcoal, I can maybe sell you enough correct leather (I bought a full hide from Connolly back in 02) to change the panel
Old Oct 18, 2013 | 11:01 AM
odds's Avatar
Hi Sean B and luc, I'm interested in both of your offers. Would you mind taking pictures and posting them here for me to examine?
luc: I'm not sure what the name of the color of the leather is in my XJR but it does seem to be a warm charcoal color. Either the leather was black originally and time/sun faded it to a warm charcoal or dark grey OR the leather was originally warm charcoal colored.
Thanks everybody for the pertinent suggestions!
Old Oct 18, 2013 | 12:27 PM
MFoncerrada8's Avatar
Where are you located? Then locals may be able to recommend specific upholstery shops...
Old Oct 18, 2013 | 01:29 PM
OldMike's Avatar
I'm not sure what the name of the color of the leather is in my XJR ...
Look at the label on the driver's door -- it has the interior code.
Old Oct 26, 2013 | 02:01 PM
odds's Avatar
I am located in Los Angeles county.
Thanks everybody for the replies. My interior is indeed made from the Warm Charcoal leather (trim code: LEG). PMs sent to relevant recipients.
Matt
philwarner
Dec 6, 2021 07:13 AM
tonimccloud
19
Jan 18, 2020 01:56 PM
thedugger1
Sep 24, 2015 05:32 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
divingmom
Aug 25, 2015 07:54 PM
