308 XJR tires
Old May 4, 2013 | 08:40 AM
Tirefriar's Avatar
Originally Posted by dmpsqrd
Why are we so attracted to super speed-rated tires when the likelihood of anyone exceeding 100 mph for more than a minute is, indeed, minute? I was just curious if someone is running lower speed-rated, less expensive and longer lasting rubber? - thanks- d
When manucturer does a suspension set up for each model, one of key factors are the tires. The XjR suspension is set up at the factory using particular tire size, tread wear, and speed rating. Using anything other then what's specified will alter ride and handling.
Performance tires usually will have a lower tread wear as opposed to a more "pedestrian" tire. The performance tires' objective is grip and it achieves that in part through softer compound, lower sidewall, etc.
If I have to worry about putting on "more sensible" tires on my XJR, then I should also disconnect several spark plug wires for a "more sensible" mileage ))))
Old Jun 2, 2013 | 01:16 AM
Disco1994's Avatar
Hi. I actually work as a mechanic at a tire shop and am really impressed by Hankook tires for quality and price. I've been dying to put a set of Hankook Ventus V2 Concept's on a car for myself, but have not yet had the chance since they don't make them in a 60% sidewall. I would go with a nice set of V2's if I were you, but I like to drive in rain, heavy snow, hot heat, and have a soft spot for cornering so these may not be what you're looking for. Good luck, let us know...
Old Jun 2, 2013 | 07:14 AM
Teddy's Avatar
Michelin Pilot Sport All Season. The temperature range is greater and lasts longer and still has the required speed rating.
Old Jun 2, 2013 | 09:32 AM
Doug's Avatar
Obviously correct!
The designers select tires, springs, shocks, anti-roll bars, etc. to arrive at a compromise they are happy with and suits their needs.
However, as owners, we're not bound by the same shackles the factory guys were and we're free to come up with compromises that WE are happy with and suit OUR needs.
Since tire technology and design is always changing it's quite possible to improve on what the factory used...as we have choices that probably didn't exist 10-15 years ago.
Right!
Heh heh, we all "worry" about different things :-)
In my case, spending $600-$800 every 11 months for new tires caused me to "worry" about how much money was going down the drain !
Old Jun 3, 2013 | 11:27 AM
SuperSport's Avatar
I was SUPER happy with my Goodyear Eagle GT's on my 99 XJR with Penta wheels. Great Wet/Dry and wear. They also look Great!
255/40ZR18
99W XL 400 AA A
Old Jun 3, 2013 | 01:06 PM
TreVoRTasmin's Avatar
I have kuhmo le on my xjr. Lasted about 10k so far but I'd expect 15k to the wear indicators 280 treadwear.
Great dry grip, good wet grip but in heavy rains you do need to slow down below 80mph as they don't dispurse water real good above that quieter than the contis that they replaced, nice ride quality. Summer only tire btw. My inspection is up in august so I'm debating on ordering another set ow or just putting other tires on it for inspection then replacing in the spring when the winter tires come off. Currently there is a $50 rebate on 4 so you're all mounted and balanced for well under $700ish.
Old Jun 3, 2013 | 06:46 PM
Jhartz's Avatar
$135 per for Michelin Pilots on Tire Rack -- why anything else? Had Pirelli 6ks on my first XJ8, lasted 8k:,switched to Pilots, looked new 25k later when I traded for a Land Rover.
Wife has the Yokohamas on her Nissan POS, 50k miles with hardly any wear. Tire Rack customers rate these second to the Pilots.
From my iPad: spelling, punctuation, capitalization errors are Siri's fault.
Old Jun 3, 2013 | 09:04 PM
  #28
dmpsqrd's Avatar
Must be different prices for Tire Rack in Virginia.... d
Old Jun 4, 2013 | 04:31 AM
Graham Royls's Avatar
Default Re Tires
On my 2001 XJR i run Goodyear Eagles 255/45ZR 18's Good looking tread pattern ideal for wet roads.
Had a problem with front tires {scalloped} and Goodyear was great in allowing me a 50% credit for replacements through Discount Tire.
Regarding Discount Tire here in Arlington Texas they give excellent service cleaning the hubs to remove rust etc when they rotate the tires.
Old Jun 6, 2013 | 01:31 PM
  #30
Jhartz's Avatar
"Must be different prices for Tire Rack in Virginia.... d"
Well, no: this from Tire Rack's Web site:
Michelin Pilot Sport A/S Plus Ultra High Performance All-Season
Special Offer:
Get a $70 MasterCard Reward Card via Mail
Sidewall Style: Blackwall
Serv. Desc: 98W
UTQG: 500 AA APrice: $134.00 (each)
Estimated Availability: In Stock
Estimated Arrival: Get EstimateQty:
Optional Road Hazard Program: Add $14.48 per tire
Add Road Hazard: $57.92
Set of 4: $536.00
After mail-in rebate: $466.00
or
Yokohama ADVAN S.4. Ultra High Performance All-Season
Consumer Rating
Warranty Rating
Serv. Desc: 98W
UTQG: 400 AA APrice: $114.00 (each)
Estimated Availability: Fewer than 7, Additional Due 06/12/13
Optional Road Hazard Program: Add $13.08 per tire
Add Road Hazard: $52.32
Set of 4: $456.00
Old Jun 6, 2013 | 03:53 PM
  #31
dmpsqrd's Avatar
How interesting- just rechecked the web site from my end- they are priced $110 more for 245/40/18's - although the rebate is listed as well, decreasing the price by ~$20 per. hmmm....
Old Jun 6, 2013 | 03:57 PM
  #32
dmpsqrd's Avatar
oops! just saw your price was for 225/60/zr16's! my bad...
Old Jun 6, 2013 | 04:55 PM
  #33
Jhartz's Avatar
No. This was my bad. I didn't read that it was the X JR that he was looking for tires
Old Jun 9, 2013 | 02:35 PM
  #34
BadMrKitty's Avatar
Hi,
After much consideration and talk with a true 'tire guy' I went with Nitto Motivos to replace my Contis. I have the same year XJR and these tires have been night and day in terms of ride comfort without sacrificing to much performance.
They have a great mileage life (I believe my tire guy said 60k), although he did recommend rotating every 3k because these cats are heavy.
Cost for tires, mount, and balance was right around $900 if I remember correctly.
Old Jun 10, 2013 | 12:32 PM
  #35
dmpsqrd's Avatar
What size tire did you use? They aren't carrying a 255/40/ZR18 (yet?) thanks- d
Old Jun 11, 2013 | 01:36 PM
  #36
BadMrKitty's Avatar
I am running 255/40/ZR18s. I'm sure why they wouldn't have them. My tire shop didn't mention any issues in getting them.
Old Jun 11, 2013 | 02:23 PM
  #37
Originally Posted by BadMrKitty
Hi,
Good luck with 'em. I know I wouldn't want anything for a performance car that got 60k treadwear as that simply means they're not the softest of compounds out there but to each his own. Then again, I'm perfectly content replacing the Kuhmo XS on my TVR ever 8-10k as they pull a g in the corners.
Old Oct 31, 2020 | 08:19 AM
  #38
Stephenph's Avatar
While a great fan of Michelin tyres,on my Saab, I use Continentals on my 308 XJR and get very good life, about 55k from each set of 235 50 R 17 Y. In the UK my quote from Black Circles at £115 v £133 for Michelin, a saving of £18 x 4, £72, (about $100).
Old Oct 31, 2020 | 11:08 AM
  #39
Jhartz's Avatar
Wow: six years later . . .
Old Nov 1, 2020 | 05:25 AM
  #40
Stephenph's Avatar
While it may be a performance car, she is a slow coach (at the time the fastest saloon car with the BMW M5 in 1999) at 0-60 in 4.2 secs. My Tesla model S makes that look slow, (the plaid does it in under 2 secs!), mine, an early model does it in about 3.7secs! I use Goodyear Eagle tyres on that!
Ireckon having raced on teh Bonneville salts flats at over 150MPH, my elderly lady deserves a quite semi retirement, doing under 500 miles a year, as a spare car!
