98 vanden plas climate control LCD back lighting
Old Dec 29, 2011 | 06:58 PM
domer94's Avatar
Default 98 vanden plas climate control LCD back lighting
seems half of the temp screen is dark. is this a matter of changing a backlight bulb behind the unit? or do i have to search for another. while im asking this, the light behind the driver side seat heat switch is out. one more... are the window switches in the rear door backlit? are any of these a simple bulb swap ?
thanks
Old Dec 29, 2011 | 09:28 PM
luc's Avatar
luc
thanks
Yes, the lcd screen has 2 bulbs behind. All switches are lighted (save for steering wheel control) but with LED I believe
Old Dec 30, 2011 | 09:26 AM
domer94's Avatar
thanks, i can find out the bulbs when i pull he unit, but do you happen to know what they are offhand? also , the seat heater switch bulb? as far as the LED's , is this something thats replacable without soldering?
Old Dec 30, 2011 | 09:31 AM
Sean B's Avatar
They're twist lock bulbs, not l.e.d's, so changing them isn't a solder job. They're not a standard fitting t5/t10 size, so the dealer is the place to get drop in replacements.
lobsterD90
Nov 12, 2022 09:51 PM
thedugger1
Sep 24, 2015 05:32 PM
Newsguy
Aug 30, 2015 11:27 AM
smokin_hobo
Aug 29, 2015 12:13 AM
DeaconHull
Aug 28, 2015 05:26 PM
