98 vanden plas passenger seat not tilting in front - motor or module?
Old Feb 8, 2012 | 10:10 PM
domer94's Avatar
Default 98 vanden plas passenger seat not tilting in front - motor or module?
would you guys say it is more likely the seat motor / drive gear of module issue? im just looking at replacements and would like to have an idea of what im possibly looking at.
thanks
Old Feb 9, 2012 | 12:21 AM
JKo's Avatar
JKo
Mine had a broken motor (only turned one way), and it had fried a relay on the control module...
Old Feb 9, 2012 | 03:01 AM
test point's Avatar
Swap the driver module with the passenger side. That will clearly tell you what the problem is.
Old Feb 9, 2012 | 04:03 PM
domer94's Avatar
thanks. as far as putting in a new module , would i have to have a dealer program it? how much of an ordeal is that?
Old Feb 9, 2012 | 08:18 PM
test point's Avatar
I bought one used and it was plug and play but matched the part number and /xxx VCAT extension. Discussions seem to be that the passenger side is not programmable. One comment from a tech was that only the '03 up SCM's were programmable.
My car has seat control modules with different part numbers and different VCAT numbers, neither of which match the car, and both worked at one time, only the driver side at the moment. Need to replace the passenger seat module.
A definitive resolution of module swapping would benefit a large number of folks.
Old Feb 19, 2012 | 06:26 PM
domer94's Avatar
took out the seat today to have a look. turns out the drive wire from the motor to the gear housing was pulled out somehow. i re-set it, threw some gorilla tape on it for good measure and now she works... i love a good ending
XJsc-guy
Sep 25, 2015 11:09 AM
bdboyle
Sep 4, 2015 06:16 AM
Dallas XK8
Sep 3, 2015 12:17 PM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
