98 VDP Brake Lights
Old Jun 1, 2015 | 09:38 PM
TheHilds's Avatar
Default 98 VDP Brake Lights
I am having an issue tracking down my brake light problem. All lights work with the exception of the brake lights. I have checked the fuse, bulbs and wire but they are all in good condition. I am going to meter for power tonight but any help for others who may have encountered this problem or have suggestions for be would be appreciated.
Old Jun 3, 2015 | 01:40 PM
Jhartz's Avatar
Are just the rear brake lights not working? Does the upper brake light work? Does your cruise control work? If all three are out and no cruise control, suspect the brake switch.
Old Jun 5, 2015 | 10:58 AM
TheHilds's Avatar
Thank you for the reply Jim. I double checked everything and the only part not working is the brake lights themselves.
If the switch was bad would it affect the cruise or could it just affect the lights?
Old Jun 5, 2015 | 02:11 PM
Jhartz's Avatar
Wouldn't rule out the switch even if cruise works. But I would start with the wiring loom at the hinge point for the trunk (boot).
But there are three brake lights: if all three are not working check the switch.
Old Jun 5, 2015 | 05:04 PM
andrew lowe's Avatar
There are 2 micro switches in the brake light switch, one does the brake lights and the gearshift interface ( locks the gear lever into park unless brake pedal is pressed ) the other the cruise.
If the high level brake light works, suspect the SLCM.
They can suffer a dry solder joint.
Old Jun 14, 2015 | 03:06 PM
TheHilds's Avatar
Thank you for the help. I found a broken wire under the dash right at the factory connector.
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
