98 XJR clunks when downshifting
Old Jul 17, 2009 | 05:04 PM
bd0nalds0n's Avatar
Default 98 XJR clunks when downshifting
As you approach a stop sign, my XJR clunks as it slows down, especially if the Sport setting is on and as it shifts down into first.
The clunking sounds like it's coming from the rear right side. I would like to suspect that it's a worn u-joint, since it's simple and would be a logical wear item. The car has ~105k miles.
Thoughts about what the most common causes/fixes are?
Thanks,
Brian
Old Jul 17, 2009 | 07:38 PM
Usdm-sti-ftw's Avatar
Thanks,
Brian
I have the exact same problem with the exact same car with identical mileage. It seems the clunking/clicking sound comes from towards the front of the tranny like the bellhousing area or even at the joint where the driveshaft is connected to the back of the tranny???
Old Jul 17, 2009 | 09:38 PM
bigcat's Avatar
Mine does it too at 61,000 miles. I was just listening to it today, trying to figure it out...
Old Jul 18, 2009 | 09:44 PM
pjkbrit's Avatar
mine also does this...86K on my 02 R. Sounds like the spider gears in the diff to me and kinda like my MGB which could be taken up with thrust washers...but that's an easy diff to get into...the Jag diff would have to be dropped and stripped. Not irritating enough for me to bother with....yet! If it starts whining...it's coming off. I did change the oil recently...needed it. Might consider putting thicker weight oil in it down the line.
Old Jul 19, 2009 | 04:51 PM
DavidB's Avatar
My 2000 VDP S/C with 75K miles does this too--it's more of a dull "pop" sound than a clunk. It happens as the transmission downshifts into first coming to a stop, and then on initial acceleration from rest. The sound can be duplicated by keeping the brakes applied and applying throttle alternately in drive and reverse.
My tech told me it was the differential, which would be a very pricey parts swap since few shops will actually work on them. I'll just live with the popping and keep my $3000.
I found this mp3 that sounds exactly like my issue:
http://users.telenet.be/jaguarxkr/Di...drivetrain.mp3
TTYL
David
Old Jul 20, 2009 | 12:27 AM
Jagster18's Avatar
Yes, that happens to my 98 XJ with 99k miles. Mine happens slowing down after long drives like highway and traffics.
So we narrowed it down to the differentials? Any quick fixes instead of a new diff? Do we have to change the differential gear oils?
Old Jul 22, 2009 | 10:23 AM
wayne1991's Avatar
My 98 xjr also does this, but if you haul *** all the time and dont stop you wont have to worry about it, haha. I dont think it hurts the jaguar at all because mine has been doing it since 50K and it now has 75k. One way you could solve it is to put a louder exhaust on or put in a loud stereo. Having the clunk sound everyonce in awhile is not worth worrying about.
vwbusbits
Oct 13, 2015 03:43 AM
xjrjag
Oct 12, 2015 03:16 PM
Tipptone
UK & Eire
Oct 1, 2015 10:50 AM
vwbusbits
Oct 1, 2015 01:17 AM
BlacXJRcat
Sep 25, 2015 06:43 PM
