98 XJR - dipped headlights work working
Old Dec 10, 2016 | 10:05 AM
sh500's Avatar
Default 98 XJR - dipped headlights work working
Hello all,
About a week ago I noticed that my dipped beams stopped working (both outer circle lights). The side lights and full beams work fine (inner circles) , as do all the other exterior lights. I have checks the relevant fuses and relays, which are all fine. Both bulbs are fine. Voltage is going to both sides too.
A few years ago, I had the issue of the lights flickering when indicating. The column stalk was changed at that time and resolved that issue.
I thought the wires may have become disconnected on the stalk, so I took off the steering wheel, etc, to check the stalk, but all the wires are firmly soldered on.
Any ideas where the fault may lie?
Thanks.
Old Dec 10, 2016 | 11:40 AM
nilanium's Avatar
Voltage is going across both bulb sockets, or the relays? If the sockets show 12v but don't light the bulbs you've got a frayed wire or grounding fault or something preventing enough current from reaching the bulbs.
Do you have the electrical guide?
Old Dec 10, 2016 | 01:00 PM
sh500's Avatar
Only checked the bulb sockets - both have 12v. Didn't check the relays. Although 12v at bulbs would mean relays are fine?
I don't have an electrical guide, no.
Old Dec 10, 2016 | 01:14 PM
Addicted2boost's Avatar
I agree with Nilanium.
It sounds like high resistance. Think of it as having horsepower but no torque. Without looking at a wiring diagram, I think the grounds for the headlights are behind the light housings if I'm not mistaken?? Basically checking all the grounds within the engine bay would be a great idea anyways.
Old Dec 10, 2016 | 07:13 PM
nilanium's Avatar
For some reason the electrical PDF's aren't included in the jaguarforums large files area. In any case, found them here JagRepair.com - Jaguar Repair Information Resource
Top list, pick out your model year, just right click to download. Invaluable along with JTIS or the compiled workshop PDF.
Old Dec 11, 2016 | 06:36 AM
sh500's Avatar
Thanks. I found the same docs last night. Will be checking the grounds. Do the LH/RH forward Ground studs, serve the headlights?
