98 xjr hard to start when warm
Old Oct 3, 2010 | 09:45 PM
Billy's Avatar
Default 98 xjr hard to start when warm
Have a 98 xjr with approx 80 000 miles. Hard to start if you shut it off when warm. No error codes come up. Have cleaned throttle body, put in new plugs. Recently had new timing chain installed. Runs smooth once it starts. Does anyone have any ideas, mechanic thinks it is probably an electrical issue with a sensor somewhere, but so far can find nothing.
Old Oct 4, 2010 | 07:07 PM
shortbus76's Avatar
Check your crank position sensor---it could be starting to fail. 1100 ohms, I think its good---less the 800 time for a new one. Double check the testing criteria and give it a shot. Testing it is a good idea as a new one is about $170.--Good luck---Scott
Old Oct 4, 2010 | 10:08 PM
Billy's Avatar
Thanks Scott. Will check this sensor.
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
XFR_Gold
Sep 2, 2015 12:24 PM
