99 Vanden Plas suspension
Old Jun 11, 2019 | 08:35 AM
Dan Callihan's Avatar
Default 99 Vanden Plas suspension
Unfortunately, even after replacing all shocks on my 99 Vanden Plas , I still don’t understand if my suspension has any kind of air assist . There were no airlines going to the shocks , yet after replacing the rear shocks ( KYB ) the rear feels a little weak !!! Is this all in my head or is there really some sort of air assist to the rear ? Please help me understand !!!
Old Jun 11, 2019 | 09:26 AM
M. Stojanovic's Avatar
There is no air assist. However, the shocks are gas filled (gas under certain pressure) which works as a spring and it is combined with the action of the coil spring. If this gas leaks out, the car will sit noticeably lower.
Otherwise, KYB shocks are known to be a bit too hard. When you said "weak", did you mean the rear sits a bit lower than where it should be or the rear is bouncing when going over bumps?
Old Jun 11, 2019 | 01:49 PM
thank you for your response . I mistakingly said that I just replaced the rear shocks with KBY shocks , however I replaced with Blistien shocks . When I press down on the front shocks they are nice and tight and they hardly travel . When I press down on the rear shocks they appear to be much looser and travel quite a bit . I replaced the shock mounts , ALL new gaskets and I’m sure they were installed correctly . If this occurred on only one side of the back shocks , I would think that I got a bad shock but both rear shocks seem too spongy . Maybe that is the way they should be on a 99 Vanden Plas . Thank you again for your input .
Old Jun 11, 2019 | 06:29 PM
Ungn's Avatar
The Front suspension also has an anti-sway bar that will resist pushing down on the fender. The back of a VDP does not.
I put the stiffer Green Bilsteins in mine, instead of the blacks and I like the tightness. I have tall tires on 16" wheels, so it still rides like a pillow.
Old Jun 11, 2019 | 11:18 PM
anduha's Avatar
Like the previous poster said the black Blistien shocks are softer and that is for the soft VDP/XJ8 ride. KYBs are much stiffer and some drivers prefer to upgrade their XJs for sportiness but the tradeoff is comfort. I put KYBs all around in my XJR but switched out to green Blistiens because the KYBs were too harsh. I doubt anything is mechanically wrong with your car by the amount of work you've done, its just a matter of ride preference.
Carnival Kid
May 6, 2019 02:50 PM
vice guy
Nov 28, 2016 08:31 AM
VIAPA2
Aug 27, 2014 08:46 AM
VIAPA2
Jun 18, 2014 07:00 PM
IreallywantaJag
Jan 2, 2013 09:42 PM
