99 xj8 timing chain failure - apparently
Old Jul 12, 2011 | 09:02 AM
err's Avatar
err
Default 99 xj8 timing chain failure - apparently
lookin at pickin up a 99 with an apparent timing chain failure at and bent valves 80k
any chance of a rebuild?
easier to just swap engines?
advice?
lookin for the quickest easiest option here
have no problem running the car with hit pistons, not a perfectionist, its just a car, as long as it runs reliably i am happy.
any place that will tell me what engines are direct swaps?
Old Jul 12, 2011 | 12:16 PM
JimmyL's Avatar
I would yank the heads off and rebuild them and be done with it. Engine swaps can get complicated and the engines changed somewhere between '98 and '03 at least a couple of times.
sparkenzap's Avatar
Would you do the swap or repair or have it done by pros?- Engines or the repair ar about $3k + installed.
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
Russ Graber
Feb 23, 2019 11:59 AM
Sprayall
Sep 3, 2015 07:49 PM
