'99 XJR--Driver Window Stuck Down
Old Aug 8, 2007 | 05:37 PM
jag_genius's Avatar
Default RE: '99 XJR--Driver Window Stuck Down
try giving the car a hard reset... disconnect the negative terminal at the battery and use the negative cable to touch the positive terminal for a few minutes then reconnect negative terminal.. and try the switch..
Old Aug 11, 2007 | 01:02 PM
jag_genius's Avatar
do the hard reset.
Old Aug 11, 2007 | 01:05 PM
93xj6's Avatar
maybe try takin off the panel and then there might be some loose wire or somethin
Old Jul 31, 2021 | 11:01 PM
Matt-97's Avatar
Default Replacement Relay?
I have the same relay gone bad in my seat control module. I couldn't find the part online, but NEC makes these:
https://www.mouser.com/datasheet/2/283/en2-6349.pdf
Not sure if they are the same, but they seem like they are in the right ballpark. This is the schematic & what it looks like overlaid on my seat module:
I may try to rebuild (clean) the relay. I'll try to post back if I figure anything out.
blackenedindustries
Sep 30, 2015 10:17 AM
Ragn0r
Sep 29, 2015 10:38 AM
