99 XJR - problems on motorway
Old Dec 5, 2016 | 12:18 PM
X308XJR1999's Avatar
Default 99 XJR - problems on motorway
I have a 1999 XJR with approximately 80,000 miles which I bought earlier this year. I have experienced two problems while driving on the motorway.
1. At approximately 65mph+, the cabin will vibrate intermittently - it occurs during acceleration, while holding a steady speed, and while decelerating. The vibration tends to worsen at higher speeds. I have had the wheels balanced, but the problem persists.
2. The engine coolant temperature is very low while running at motorway speeds: it is generally on the border with the blue segment. On one occasion, it fell right to the bottom and an orange warning light and "Restricted Performance" appeared.
Has anyone experienced either or both of these problems, and if so what is the solution?
Many thanks for any assistance.
Old Dec 5, 2016 | 12:31 PM
RJ237's Avatar
Intermittent vibration is a tough one. Check the rubber jurid coupling in the driveshaft.
Change the thermostat.
Old Dec 5, 2016 | 12:55 PM
Many thanks for your prompt response. That's very helpful.
I should have mentioned that the engine coolant temperature is normal during stop/start driving (i.e. in town). Is that still indicative of an issue with the thermostat?
Old Dec 5, 2016 | 02:24 PM
RJ237's Avatar
That's when there is little airflow through the radiator. I'm wondering if you even have a thermostat.
Old Dec 5, 2016 | 05:55 PM
Addicted2boost's Avatar
+1 on the driveshaft coupler. Even though the car has relatively low mileage, it's also the age of these cars that reek havoc on the materials hence the rubber couplers are no longer pliable and turn hard as a rock. Or you may also have a coupler just coming apart.
Sounds like your thermostat is stuck open.
Old Dec 5, 2016 | 06:50 PM
ericjansen's Avatar
It should help if you mention where you are located.
Big difference if arctic or tropical temperature air flows through radiator .
Does your interior heat also drop down?
Old Dec 5, 2016 | 07:06 PM
I'm in the UK, and it's a little chilly at the moment. That may explain why the temperature is so much lower. Yes, the interior temperature is also lower.
Thanks for the very helpful replies. I'll ask a garage to have a look at these.
Old Dec 5, 2016 | 08:01 PM
Mark SF's Avatar
The thermostat is intended to have a rubber gasket around it, to get a good seal. I had a problem where the thermostat was working OK, but the gasket was not installed, so enough water was leaking past to make warm up very slow, and in cold weather on the highway the engine would start cooling down.
Old Dec 13, 2016 | 06:52 AM
Vector's Avatar
My R type is very sensitive to out of round or out of balance tire issues.
Get a "Hunter Road Force" balance job done by someone who knows how to do everything the machine tells them to do.
+1 on the thermostat, either you don't have one, or it is stuck open.
Vector
Old Dec 13, 2016 | 08:25 AM
The vibration appears to have been caused by incorrect wheel balancing after all - that is now fixed. A new thermostat has, I think, solved the temperature issue.
Thanks again for the replies.
Old Dec 13, 2016 | 02:39 PM
Jhartz's Avatar
sometimes it is the simple things . . . . . .
