ABS Module Repair Fail?
Old Aug 9, 2016 | 02:11 PM
KidRock'n's Avatar
Default ABS Module Repair Fail?
Hi gents,
Was getting an intermittent - and then consistent - ABS light with traction & stability control fail in my 99 VDP. Took it to dealer who scanned it and told me it was showing the 1095 ABS module code. Elected to remove the module, had an electrical shop open it up, repair the solder joints in the lower right hand corner of the module and urethane seal it back together. Put the module back in the car but still getting the ABS code. Perhaps the circuit board in the top right hand corner is worth a look also? Or are there any other potential issues that could give me the 1095 code? Both the dealer and the forum have suggested that this reading is due to solder joint failure in the module. Let me know your thoughts or if I can provide further information.
Cheers,
David
Old Aug 9, 2016 | 04:01 PM
RJ237's Avatar
It could be the pump, but that is rare. Measure the resistance across the contacts in the plug, I usually get around 11 ohms.
Old Aug 9, 2016 | 09:49 PM
LeLimoMan's Avatar
Ok. Maybe I'm totally out in left field on this, but am I correct in saying that the ABS, trac and stability control fault lights can come on as a result of a bad or dying battery? These systems are very voltage sensitive and my car had the same issues intermittently. Changed the battery and redid the many of the grounds. That seemed to solve the issue and I haven't gotten these faults since.
Old Aug 10, 2016 | 12:24 AM
dsetter's Avatar
If you're checking the motor plug, you will be able to check that the motor plug is plugged back in, and connections look OK. The bad connection causes heating and weakens the plug connections.
This is the second lower plug and often gets reduced attention when reinstalling.
Old Aug 10, 2016 | 04:52 PM
KidRock'n's Avatar
Hi guys, fairly confident this is not the result of a bad battery or ground, but I will test again this weekend. Will also have a look at the plugs as well and report back. Thanks for the feedback
Old Aug 16, 2016 | 03:46 PM
KidRock'n's Avatar
Hi gents,
Can confirm that it is not a battery issue. Ran a bunch of tests on the battery and all came back good. ABS/Trac/Stab lights are consistently intermittent as they were before.
Next steps: Check the resistance across the contacts in the plugs and clean them with electrical cleaner?
Old Aug 16, 2016 | 07:05 PM
RJ237's Avatar
I recently had to resolder the pins on my XJ6. I did the repair about three years ago but the light came on again a couple of months ago. I thought I had good flow of the solder, but it didn't hold up. This time I used some paste flux and silver solder.
Old Sep 2, 2016 | 08:48 AM
KidRock'n's Avatar
Thanks for the reply. I removed the module, cut the entire right side top cover piece off with a hacksaw and gave it another on all of the joints. Reinstalled it and no lights since. Temporary victory over the VDP
Nee_the_Bogeyman
Apr 3, 2016 10:41 PM
innzane
Apr 3, 2016 08:43 PM
hub61
Mar 26, 2016 11:20 AM
hub61
UK & Eire
Mar 26, 2016 11:08 AM
Mar 16, 2006 03:10 PM
