vincent661983
close
- Join DateOct 2010
- LocationNew York
Liked:169 Times in 142 Posts
All kinds of warning lights start on and off from my dashboard.
one thing Ive realized that they come out when I on bumpy road surfaces.(welcome to NY,we have the third world country grade road surface and any public infrastructures)
FYI,I just changed my vacuum booster hose and connector for 180 for the parts alone.(another Jaguar rip off)
Please help
Please help
RJ237
close
- Join DateDec 2010
- LocationDouglasville Ga.
Liked:2,924 Times in 2,317 Posts
I expect a bad or loose electrical connection and would start right at the battery, both pos. and neg.
motorcarman
close
- Join DateDec 2009
- LocationWise County,TX
Liked:9,638 Times in 5,765 Posts
There are TSBs for INST PK and network faults but they are usually VIN specific.
Sorry you won't share more info about the car.
bob
bob
Sean B
close
- Join DateOct 2008
- LocationSunny Southport UK
Liked:1,425 Times in 1,110 Posts
It sounds like a bad connection on one of the major can-bus modules, as Bob has mentioned the inst pack, also the trans shifter harness connection can do this. You'll need to check both.
@ Bob, I think Vincent's car is an XJR - but we shouldn't assume anything lol!
vincent661983
close
- Join DateOct 2010
- LocationNew York
Mine is xjr (reincarnation of my crashed xjr100). What exactly is can bus module? Is it the same thing as abs module? Where is that located ? Pictures or diagram will helpOriginally Posted by Sean B
It sounds like a bad connection on one of the major can-bus modules, as Bob has mentioned the inst pack, also the trans shifter harness connection can do this. You'll need to check both.@ Bob, I think Vincent's car is an XJR - but we shouldn't assume anything lol!
RJ237
close
- Join DateDec 2010
vincent, you have been here for years, I don't understand why you haven't downloaded the relevant electrical schematics from the stickys or jagrepair.com. The CANBUS is a computer network connecting the main modules, usually a green/yellow wire pair in the schematics.
