air temp different on passenger side vs driver side help?
Something I am completely confused by
While running AC the driver side left and middle left vent are noticeably cooler (haven't tempt it but drastically 12 maybe 15 degrees cooler) than the passenger. driver side feels icy passenger side almost as though Ac doesn't exist.
Middle right and right vents are significantly warmer almost as though the AC wasn't on?
Rear vents are what they have always been - just there for fun seemingly not doing much but do still feel cooler than front rights.
Any idea on the cause or what to attempt to do to fix. I'm really lost on this one
99 xjr
99 xjr
Fortunately , the trim door motors can be run back and forth as you put a 9 volt battery on the climate control module connector ( not as buried as the motor connectors ) and with a good ear you can hear the target motor run , this proves motor good and just motor position sensor bad ( so it goes wonkers ), there is a work around at this point not needing to dig out and replace motor
You have a cabin climate control panel cabin face bite test that will identify specifically the motor by fault code numbers found in the X308 TSB list
This is a Youtube video someone made of almost the exact same Denso system on the X300 ( minus the center vent trim potentiometer negated on the X308 )
See page 110 0f the doc linked below
T703 BOOK
T703 BOOK
TsJaguar
Jun 1, 2016 02:51 PM
trashdi
Aug 24, 2012 09:22 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
