Another tensioner question
Old May 17, 2011 | 01:24 PM
test point's Avatar
I would install the new tensioners and chains and set/verify the cam timing first to be able to check compression. If you broke the chain you should be able to rotate the exhaust cam until you can get all the exhaust valves closed and be able to do the compression test before the replacement/timing. If you can get the intake cam into the alignment position (flat alignment surface up) none of the pistons are at TDC and then you can rotate the exhaust cam.
You mention primary tensioners but the ones that usually fail are the secondary, exhaust cam, tensioner/chains. Check out the FAQ sticky at the top of the XK8/R forum to find several links to everything you wanted to know about the work.
Chains can jump a link and do no damage or they can bend a valve. The chain can also break and leave the exhaust cam in a position to do no damage. Taking the head off to see is way down my list of things to do first.
. . . and welcome to the forum! All are here to help.
Bowman
Sep 15, 2015 06:54 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
davidladewig
Sep 11, 2015 06:48 PM
Bcrary3
Sep 11, 2015 10:36 AM
convincor
Sep 10, 2015 06:50 AM
