Fuel Pumps
Old Apr 13, 2011 | 04:44 PM
SteveM's Avatar
Default Fuel Pumps (higher flowing, aftermarket)
So it looks like my primary fuel pump has failed. I removed the relay to first pump and now I'm running on the second pump. (By the way, no restricted performance or codes that I read were supposed to occur by doing this.)
I was wondering if anyone had installed a higher flowing fuel pump, like a Walbro 255 lph or similar without any issues?
I plan on significantly increasing the power in the future and would like to put a higher flowing pump in while I'm in there. I probably would leave the first pump stock and upgrade the second one.
Now I know the 2 stock pumps apparently flow enough for over 600 hp, but good, higher flowing pumps could be bought for cheaper than the stock types so I would prefer to use one of these. Besides, I have a new Walbro 255lph lying around that I bought for $70.
Edit: The restricted performance eventually came on after about 200 miles with the primary pump relay pulled.
Old Apr 13, 2011 | 05:34 PM
plums's Avatar
One consideration would be whether the in tank wiring is up to the task. Especially the link wire.
I have three black hoses for sale. They are 3.5" / 89mm inner diameter and are about 6 1/4 inches long. They are new never used, just extras from making my intake. 4 ply construction, SAEJ20 compliant, hand wrapped in the USA.
Any underhood pictures of the intake you made?
Old Apr 13, 2011 | 06:05 PM
SteveM's Avatar
I was wandering if that would be an issue.
Yes, in this thread:
https://www.jaguarforums.com/forum/j...-intake-44927/
Old May 17, 2011 | 04:44 PM
SteveM's Avatar
Well, I ended up installing a Walbro 255 lph in place of the stock secondary pump. No issues so far.
The Walbro is longer than the stock pump so I had to modify the pump bracket by boring out the circular top part so that it slips through. Also had to splice the wires together.
I should be good for 800+ horsepower.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
