Average cost to have independent shop preventatively replace tensioners??
Old Jan 4, 2012 | 01:14 AM
Newby's Avatar
Default Average cost to have independent shop preventatively replace tensioners??
Approximately how much does it cost to have the tensioners upgraded/replaced and independent shops? I've seen the $600 figure, is that for a shop to do it, or just for the parts to do it? I'm assuming that is labor and parts, but I don't want to assume.
I live in the San Francisco Bay Area if that helps.
Thank you in advance.
I am new here and don't have enough posts/days to do a search, so sorry for asking what I'm sure is a very often asked question.
Old Jan 4, 2012 | 04:15 AM
test point's Avatar
Welcome to the forum! You should be able to do a search, just limited on downloads. Say hello to a few folks in the new member section and you will be there.
Ford parts for the upgrade, tensioners and bolts, are about $130, FelPro gasket set about $40. Labor about 4 hours. Labor rates vary widely. Some will only provide parts.
Not a difficult job, if you would try to replace spark plugs you can do this.
It would help if you would put your model/year in your signature
Old Jan 4, 2012 | 06:49 AM
Newby's Avatar
Thank you very much
xjrjag
May 21, 2026 09:05 PM
reedmtn
Jan 15, 2016 07:24 PM
Bcrary3
Sep 12, 2015 08:43 AM
rootbeerlover
Aug 31, 2015 03:37 PM
Bcrary3
Aug 31, 2015 11:29 AM
