Back Shocks 1998 X308
Old Jan 19, 2014 | 05:00 AM
norrimac's Avatar
Default Back Shocks 1998 X308
Hi all, good morning!
I have an intermittent fault in the suspension dept. in that the CATS system is flipping into its default (rock hard) mode.
I've been advised that first thing to check is the wiring connections to the shocks themselves.
Front ones are easy enough, but can anyone tell me how to access the tops of the rears? Back seat out maybe?
Thanks, Norm.
Old Jan 19, 2014 | 05:47 AM
xjay8's Avatar
Thanks, Norm.
Greetings Norm,
First course of action would be to have any codes read.
Unless you can access the wires in the boot/trunk behind the inner covers, you will have to remove the rear shocks.
But before you have to go to that extreme, try perusing a wiring diagram to see where the harness connectors are located.
You may be lucky and find them in an easy location but there is the end that actually coonects to top of shock and that would mean shock out.
Old Jan 20, 2014 | 05:48 AM
norrimac's Avatar
Thanks friend.
Apparently I can get to the shox tops thru the trunk.
I tried to get the codes read, but according to the Jag dealer, the '98 system is so Jurassic, all it says is 'Suspension fault'
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
KarimPA
Sep 12, 2015 08:15 AM
Busa R
Sep 3, 2015 05:01 PM
OkieTim
Sep 2, 2015 12:48 PM
