Bent Subframe
Old Oct 27, 2016 | 12:48 AM
srhodes87's Avatar
Default Bent Subframe
The ears at the front of the subframe that sandwich the lower control arm knuckle are bent back and rubbing slightly.
A friend of mine who is a jag/rover tech at the SF dealer says this is a common issue. Is it worth repairing and if so how difficult is the job?
Old Oct 27, 2016 | 06:14 AM
convincor's Avatar
Should be fairly strait forward fix with a hammer and punch/chisel of some sort.
Someones been pulling up a little to close to curbs..
When I bought my 98, the radiator was pushed back and popped out of the lower mounts.
