Big Explosion...total loss of oil :-(
Old May 10, 2017 | 04:42 AM
Originally Posted by Benson7
Hi Community,
Just got back home after "loosing" my car on the side of the motorway....
Suddenly a big explosion after changing gears and total loss of oil....
Anybody can tell me if I can still save the car ? What could it be ?
Thanxs
Sorry to hear about your recent disaster. Although the cause is still speculation until the vehicle has been examined, loud mechanical bangs are usually accompanied by severe structural damage.
There's 3 critical items of information missing from your post:
1. Model and Year
2. Location
3. Technical experience / ability / facilities
I saw you subsequently added Model and Year in a later post. I've now added this information to your forum Signature so it appears automatically with all your posts.
Location is important because it will influence how and where you can source parts or a replacement engine. I can see you are in Switzerland but members cannot access this information.
Your technical ability will influence the descision to repair or replace. If you cannot do the work yourself, the labour and parts cost of an engine rebuild will easily exceed the value of the vehicle.
Regardless of DIY or using a professional, a used replacment engine is the quickest and lower cost option if there is major damage.
Old May 10, 2017 | 07:03 AM
Benson7's Avatar
Originally Posted by Einhead
If you can find a good original spare engine with the correct partnumber and with preferebly low milage and a known service history, its a matter of pulling the old egine out and tuck the "new" one in.. that should be pretty straight forward.. or not.. hmm
What you would need is new packings to exhaust, consider the status of the engine mounts etc. etc.
The price on an spare engine may vary depending on how it is equipped.. if it is stripped from generator, starter, kompressor, inlet etc., you may need additional packings in order to move over ok parts from your own engine..
Some homework to do im afraid..
/E
thanxs for the help and support
Old May 17, 2017 | 12:16 PM
Benson7's Avatar
Hello everybody, I think that I have found an engine for my car. The engine comes from a 2001 XJR (like mine) but the engine was manufactured in may 2000. That means it has Nikasil lining. I have read a lot about the problem...but my theory is that the engine should be good since high sulfure petrol was banned in europe since 2000. However, there is no way to check if the car suffered heating problems.
What are you thoughts on this ? the engine has only 75'000 km's
Thanxs for your feedback
Old May 17, 2017 | 03:06 PM
RJ237's Avatar
I consider nikasil to be superior. Do a leakdown test or check the linings with a boroscope. It's extra work, but if you remove the heads and replace the gaskets with the 4.2 mls there will be little chance of blowing a head gasket in the future.
This would be a good time to replace the chains and guides, and of course the tensioners if that hasn't been done.
Old May 17, 2017 | 03:48 PM
Mikey's Avatar
Have you determined whether the engine needs to be replaced or not? If yes, what went bang?
Old May 17, 2017 | 06:22 PM
Benson7's Avatar
hi mickey, yes the engine needs replacement. The piston "went through the engine" and pierced it :-( therefore there isn't much that can be done
Old May 17, 2017 | 06:25 PM
Benson7's Avatar
ok thanxs for your feedback. Why do you consider it superior please ? All I read is bad publicity
Yes, if i get the engine I will definitely adresse this issue (tensioners)
Old May 19, 2017 | 07:45 AM
  #28
Sean B's Avatar
Nikasil V Steel engines....
Nik are overall a lighter engine because they're coated bores, not steel inserts.
Nik does not wear - so in theory will last far longer than steel.
Nik is used in pretty much all racing engines because of the two points above.
But - the crappy high sulphur fuel didn't just wreck the Jag units, Porsche and BMW had exactly the same issues with having to fit replacement engines, Jaguar had to return to steel because of the petrol offered at that time - effectively Sulphur is Nikasil's Cryptonite.
I've said it before on here and I'll say it again - if there was 2 bare blocks, nik and steel, I would take the nik engine over steel every day because of the benefits which manufacturers quite rightly chose as the better option.
But, care must be taken when buying a used Nik unit, a compression test/leak down test should be carried out before parting with the cash, this is to confirm the linings are good.
Old May 19, 2017 | 01:11 PM
Benson7's Avatar
ok thanxs for your feedback. Very helpful :-)
can it also be checked by looking at the bores (when buying the engine on a transport palet) ?
