Breather tube hack advice
Old Apr 2, 2013 | 07:33 PM
michaeldeanrogers's Avatar
Default Breather tube hack advice
I had a leak from the heater hose that goes under the supercharger, so removed the SC Sunday to do the repair. Unfortunately, I busted a breather hose that runs from the front under the SC to the throttle body, where it Ts on... I broke it right at the T, and my question is this: would a repair from a tube of JB Weld be acceptable, or other suitable adhesive?
The darn thing is $50 plus shipping, and has to be ordered, so time is an issue (well, so is cost). It's part description is HOSE-PART LOAD B, part number AJ84879.
This is a breather tube from the valve cover, so it seems to me my hack should be OK.
Opinions or advice?
Old Apr 3, 2013 | 11:04 AM
SuperSport's Avatar
Opinions or advice?
I fixed mine with some Black RTV. I got a copper tube just large enough to fit inside the hose then spliced it back together using Black RTV as the glue. Never had trouble after that. Just be sure the RTV you use is fuel/oil/temp safe.
Old Apr 5, 2013 | 12:08 AM
Good idea, SS. I got good results with the JB Weld, the fix is stronger than the hose.
Had to get it set using some duct tape and 5 minute epoxy sparingly used just to hold it for the JB Weld. Let the 5 min cure for an hour, put the JBW on generously, and it is solid and airtight, and did not change the inner diameter.
Poet
Feb 7, 2025 02:18 PM
Joachim1167
Nov 7, 2020 09:18 PM
xjrjag
Oct 12, 2015 03:16 PM
caldoofy
Sep 28, 2015 08:43 PM
