Broken washer nozzle
Old May 25, 2017 | 03:52 PM
3timejag's Avatar
Default Broken washer nozzle
The washer nozzle on my '98 XJ8 broke off at the hood end. Does anyone have a video or access to some instructions on how to replace it? I THINK I found the right past on eBay, but if it's a real task to access to plate where it seems to be " installed" I may just live without.
Many thanks!
Old May 25, 2017 | 05:01 PM
nilanium's Avatar
part is GJA8969AB
I think you need to pull the lower windscreen plate/drain cover to access it, should just pull the wiper off and then the torx screws?
Old May 25, 2017 | 05:27 PM
3timejag's Avatar
After looking again, I got adventurous and did just that to see if I could acres it. Replaced everything and now I'm just waiting on the part. You are correct!
Thank you sir!
Old May 26, 2017 | 12:25 AM
King Charles's Avatar
https://www.jaguarforums.com/forum/x...number-146630/
Old May 26, 2017 | 07:02 AM
3timejag's Avatar
Second time you have helped me out, thanks "King"!
