Car over heating !!!
Old Jul 1, 2015 | 10:00 PM
san2slim38's Avatar
Default Car over heating !!!
I need help ! I own a 2001 Jaguar XJR Supercharge and my car is over heating. I have had the coolant hose, thermostat, water pump, and coolant tank replaced but my car is still over heating. the oil was checked and no mix, no white smoke coming from tail pipe to indicate a blown head gasket but my car will over heat after driving about ten minutes, I can let it run, turn ac unit on while the car is running(in park) and the temp gauge will display normal but soon as I drive the car after 10 minutes the gauge shoots all the way up. Lost and confused. can you help, thanks
Old Jul 2, 2015 | 02:02 AM
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Jul 2, 2015 | 02:25 AM
plums's Avatar
Look up the posts in this section about the proper orientation of
the bleed lines at the coolant expansion tank. Lots of people
install them so that they "look right". That is wrong. They should
be crossed. You'll understand once you see the pictures.
Old Jul 2, 2015 | 06:23 AM
san2slim38's Avatar
I cannot find the posts in this section about the proper orientation of
Old Jul 2, 2015 | 07:19 AM
test point's Avatar
https://www.jaguarforums.com/forum/x...74/#post443126
fast40driver
Apr 19, 2024 07:24 AM
1100me
Aug 27, 2020 11:37 PM
Xj812
Oct 26, 2015 05:04 AM
BlacXJRcat
Sep 8, 2015 04:49 PM
Marque
Aug 27, 2015 11:53 AM
