Changed timing chains and tensioners - Went smoothly
Old Feb 28, 2012 | 07:47 PM
CortComp's Avatar
Default Changed timing chains and tensioners - Went smoothly
For once I actually get to start a thread that has a happy ending
Last sunday I replaced the timing chains, tensioners and water pump - good thing since the old tensioner rails were pretty cracked. It took a while, but everything came apart and went back together pretty smoothly. The only sticking point we had was getting the dampener off - we were about 30 seconds away from cutting it off and ordering a new one before one last try finally budged it loose.
One thing that helped me was I removed the radiator completely (be sure to plug the transmission lines) and I unbolted the AC condenser and dryer and carefully bent the lines back so the condenser was sitting back towards the engine (without disconnecting any lines). This not only have me a lot more room to work and get at the dampener, but it also moves the radiator out of harm's way.
I also adjusted the throttle cable, as per one of the posts on this forum. Holy crap, it drives like a new car now! Before there was so much play that you could push the pedal down 1/3 of the way before engaging the throttle. Now it downshifts where it should and I even get slightly better mileage too. And it was super easy (and cheap!) to do.
I still have a little bit of a rough idle, and the VVT solenoids are making noise intermittently (I'm guessing), but it's due for an oil change and I've heard to put 10W-30 in it and that might help with that.
Old Feb 28, 2012 | 08:26 PM
Nice one and a positive post, thanks for sharing
Anything else to add, please let us know!
Old Feb 28, 2012 | 08:41 PM
test point's Avatar
. . . and welcome and thanks for a great introduction to the forum.
Old Feb 29, 2012 | 06:22 AM
Well done, feels good doesn't it?
xjrjag
Nov 27, 2025 09:16 AM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
souldoubt
Aug 25, 2015 08:15 PM
