Christmas SOS
Old Dec 24, 2015 | 11:50 PM
AfricanJag's Avatar
Default Christmas SOS
Hello Jagexperts,
Can't believe what I have woken up to. My engine bay is filled with a most horrifying sound. Could it be the chains? Can I drive her? Here is the problem: https://drive.google.com/file/d/0B3t...ew?usp=sharing Will be grateful!
Old Dec 25, 2015 | 07:15 AM
convincor's Avatar
I'm not going to click on it, you click on the link...
I'll just say NO, don't drive it.
Old Dec 25, 2015 | 09:00 AM
CharlzO's Avatar
I would leave driving it to being very limited on an only if you ABSOLUTELY have to. I can't tell you exactly what it is, but I do know that it's never a good sign. Assume all the fluids are at the proper levels? I'd be worried that there might be a bearing going somewhere in the lower end, but it's hard to tell from a video.
Old Dec 25, 2015 | 10:42 AM
RJ237's Avatar
It's probably internal, but just to be sure, remove the serpentine belt and start it briefly. That will eliminate the idler, tensioner, pump,etc.
Old Dec 25, 2015 | 11:11 AM
AfricanJag's Avatar
Thank you gentlemen for the advice. Keep it coming.
Old Dec 25, 2015 | 11:18 AM
AfricanJag's Avatar
I would also like to add that each time I revv the engine the knocking sound in the video is followed by about 4 clicks (which sound like the starter motor solenoid clicks when the car is about to be started).
Old Dec 25, 2015 | 07:10 PM
Addicted2boost's Avatar
That to me sounds like it could be a tensioner going out. There's only one way to find out! Don't keep starting the engine up until you've pulled a valve cover.
Perry Fisch
Jan 9, 2016 03:25 PM
dvsadam
Dec 31, 2015 08:27 AM
XJeej
Dec 27, 2015 01:17 PM
SickRob
Dec 24, 2015 04:24 PM
280zx-turbo
Dec 24, 2015 09:06 AM
