clock light bulb for 1998 XJR
Old Dec 31, 2010 | 09:43 PM
HARV's Avatar
Question clock light bulb for 1998 XJR
Hello,I need the little light bulb for the clock in my XJR,do I need to get this from a dealer?Thanks for the help
Old Jan 1, 2011 | 04:10 AM
Cadillac's Avatar
As this place is mainly made for new members introductions I moved off your thread into the proper area
Old Jan 1, 2011 | 11:06 AM
DavidN's Avatar
You'll need a OEM bulb, as this special bulb is of a blueish/greenish color.
To exchange the bulb you have to remove the center vent.
- Pull off the center veneer
- Pull off the veneer cover of the instrumant cluster
- Pull off the veneer covering the passenger airbag
- remove a few philips head screws and pull off the center vent
- Now you have access to the clock
(Part # of the bulb is imprinted on the back of the clock)
HTH
David
Old Jan 1, 2011 | 12:19 PM
HARV's Avatar
Thanks David, I got the clock out and found the part # for the bulb.
99xk8guy
Sep 29, 2025 10:51 PM
Rlover
Mar 30, 2016 10:04 PM
afterburner1
Dec 16, 2015 12:12 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
gene1
Sep 3, 2015 05:58 PM
