complete brakes replacement on a 2015 jaguar xj
Old Mar 7, 2018 | 11:42 PM
Codeman's Avatar
Default complete brakes replacement on a 2015 jaguar xj
i've been told I need to complete brakes replacement on my 2015 Jaguar XJ. The dealer is quoting a price of $2200, is this realistic or am I being had? The auto has 47,000 miles.
Old Mar 8, 2018 | 12:39 AM
AZjag1999's Avatar
Your post would have better responses if it were under the current models in the XJ (X351) forum. But I did both my rear rotors and pads for about $130 for parts and I did the job myself (for my 1999 xj), so no labor costs. You can also look for a jaguar specialist in your area.
Also, take a look and inspect your brakes, if your rotors are smooth and there's enough depth to them (measured best with a vernier caliper), then they should be good. Then, check your pads. There's usually pad indicators that screech to indicate low brake pad depth. Check for excessive brake dust. Overall, if it feels like your car can brake well, then it should be good. But, at the same time, your brakes can determine whether you can stop in time or not, so heed to any warnings of bad brakes.
But, to answer your question, yes around $2k for parts and labor for all four rotors and pads seems correct from the dealer.
Digital Will
Feb 21, 2026 05:58 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
richardneiden
Oct 16, 2016 08:53 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Envy337
Apr 15, 2007 03:47 PM
